H/K AVR 1650 - get it?
I
Indianaman79
i found a smoking deal on an H/K AVR 1650 - i would be replacing an H/K AVR 247 - is it worth spending $$ for this upgrade? I would primarily be using it for movies and games. thanks in advance!
afterlife2
afterlife2
The only difference is the Dolby TrueHD and DTS-HD Master Audio decoding. With the 1650 it's only 5.1, but the 247 has 7.1. I'd keep the 247 If the Dolby TrueHD and DTS-HD Master Audio isn't something you really want or need.
