H/K AVR 147 Not detecting surrounds
krzywica
krzywica
Hey guys....
I am trying to use the EZSet-EQ feature with my setup mic as I cannot locate my SPL meter and when I run it I get to the surrounds and the receiver doesn't detect them even though I get a test tone out of them. Any ideas?
Adam
Adam
Does the microphone position have objects (like the back of a couch) significantly obscuring the sound from the surround speakers?
krzywica
krzywica
Nope none at all.....I even put the mic on top of a box so it would be at ear level.
Adam
Adam
You've got me stumped. :)
You say that you get a test tone, and I'd like to verify my assumption on that. When you say that, you mean that the set-up routine plays a tone through them but doesn't detect that tone through the mic?
Votrax
Votrax
Run the test tone again to ensure you didn't swap the surround left and right speakers.
Adam
Adam
I was thinking that, but wouldn't the receiver still say that the speakers were hooked up even if they were reversed?
That's a good suggestion, though.
Votrax
Votrax
Good question Adam...probably can't tell the difference now that I think about it. Maybe polarity is incorrect or one speaker isn't working.
krzywica
krzywica
Thanks a lot for the help guys.....
I do have the polarity correct on both speakers and they are both working perfectly.
I do have both speakers on their appropriate left and right channels.
I do not have any idea why this will not work.
I was thinking maybe those speakers aren't as effecient as my front soundstage so the mic will not detect them.
I know the mic is not defective as I have used it on other receivers for auto setup.
Any more ideas?
