Hi there,
I was wondering if some people here could help me out with a problem that came up with my H/K AVR 145. I am trying to access the on screen display but I am only receiving a distorted signal, with no visible menu. I am fairly confident that I am following all of the instructions that are listed in the manual properly (i.e. using either composite or S-video cable monitor out, since the OSD cannot be accessed through the component video out)
Has anybody ever encountered this with an H/K receiver? I did a system reset, but it didn't fix the problem. Is there any other form of reset I can do to fix this? I sent an e-mail to the H/K technical support, but nobody is responding. It's under warranty, but I would prefer not to lose it for a month if this is a relatively easy fix.
My ultimate goal is to be able to set the crossover frequencies, so if anybody knows of a way to do that without accessing the OSD than I would greatly appreciate the help.
Thanks in advance!
Tokai Guy
