After reading the Need Guidance buying 5.1 HT Spkrs & Receiver thread I too need guidance. I have similar needs with a smaller budget - so needless to say i'm jealous already.
Budget: 1k <-- Baby due in 3 weeks. I'm lucky to get approval on that, if you have kids you know what i mean.
Need: 5.1 or 7.1 setup (speakers and receiver) *see Q's below.
Room size for HT: The basement is a "L" shaped: HT (zone 1) is basically the littlier part of the L, because of a pole, the viewing screen will be viewed from the Right to the Left part of the "L". (see below)
The size of Zone 1 is 13' across the front x 20' from front to rear.
*my attempt to draw the layout doesn't come through after posting. Only visible in edit mode.
_____
| | < --- zone 2
| ... _______
front | | < ---zone 1 (rear)
|___________
Currently wired for 5.1; (I didn't do it). The front L/R are 6' high in 9' ceilings the center @ 2' high and the rear are actually mounted in the ceiling at 13ft back from the room (directly over head of 1st row seating).
So - my questions.
Q1. My initial thoughts were go with 5.1 however I've never seen a 5.1 setup with the rear overhead; is this going to be a big issue? I thought maybe I'd be better off to go with 7.1 since the middle could? be overhead? This threw a wrench in things; although maybe someone knew what they were doing before me.
Q2. I have 4 speakers in various locations in zone 2 (bar/pool table etc) so ideally I'd like 1 directv box and be able to send video/audio to either zone 1 or zone 2 - not sure if this can be done easily short of 2 directv boxes or some hdmi splitter or is there a receiver that can do this already?
Q3. I dont' necessary have to go with wall units for the front; as I could drop the plate down - but if wall mounts are the best for my budget then i'm fine with wall or floors. In walls would be awesome but again - i'm looking for bang for the buck so...Oh, the sub is wired for the back of the room too...
I don't think I'll get a 5.1/7.1 + 4 extra speakers and a receiver for 1k so right now i'm focusing on the HT (zone 1) and will add speakers to zone 2 later.
Wireless, bluetooth, airplay and all that - a nice to have.
Q.4. I was thinking of hanging a heavy like "curtain" material between zone 1/2. There is no natural light so this would serve as a video and some sort of audio containment/partition. Any recommendation there?
Thanks in advance!
