o51974 said:
Thanks for your info. As a newbie, I am glad that I did not get into a wrong forum. Like lots of newbie out there, I am confused with "marketing terms". Obviously, the "SUB cable" is the one trap that I fell into.
I am also concerned with what's the right way to do "it". Unless I am given all kinds of cables in front of me to play and test with, I simply don't know if I do a bad job or make a wrong choice on cables...etc.
Just curious, what makes you choose the radio shack one?
Cables are a big trap in the audio world. Some swear that they make differences. Others, myself included, swear they don't. There are intense discussions/wars about this all over audio forums. One thing is for sure, most boutique cables are way way over priced. Monster Cable is a good example of this and they are extremely inexpensive compared to some. There are 3ft cables than run into the thousands of dollars. They look awesome but how much are looks worth?
My best advise and other will probably chime in for and against as well, don't spend a whole lot on cables. Radio Shack Gold Series, AR, Dayton, lower priced Monster, RCA, Pheonix Gold, etc. can all be had a good values. Generally under $30 or so. Then there is the "next" level up where cables run about $50 to $100. These are expensive to me but for some they are a good value and I do think generally they are. There are some good advertisers on this site than have some really nice cables that won't break the bank. Personally, I like Radio Shack Gold series because they are well made physically and there is a store about 1 mile from my house. And, they are pretty cheap. I don't think I have ever paid more than about $25 to $30 for a cable.
Anyway, hope this helps.
Shinerman
