Thanks Slipperybidness. The safety ground should be for a lightning strike or surge. I could see a surge coming into an AV receiver from the cable line in, even though it's grounded at the service entrance.
Nope!
The safety ground is for YOUR safety! It provides a very low resistance path directly to ground. So, if a live wire comes loose and hits the metal chassis, then the current should take the path of least resistance to ground (through the safety ground) and NOT through you and your heart! Furthermore, that large instantaneous current should blow fuses and/or trip breakers at the panel!
In general, if your house gets struck by lightning, you're hosed!
My neighbors house took a direct hit! Then lost EVERYTHING that was plugged into an outlet! It got my computer, and I was dang lucky that was all that I lost!
And, in general, cable companies are notorious for terrible grounds on their systems.
If you look at very old houses, they don't even have 3-prong receptacles! There was a time when there was no such thing as a safety ground!
