Ground Loop that just won't go away
bri1270
So I've grounded my cable tv to the water main (along with my mains), I've checked every cable connection, inside and out, to make sure they were properly fitted, I only have one splitter for the three TV's in the house, and I can't get the hum to stop. Granted, it's only audible from about 2 inches away from the speaker, but I'd like to get rid of it completely. If I remove the CATV from the wall the hum is gone, so I know it's being caused by that. So what the hell is going on??
Rob Babcock
Rob Babcock
Moderator
That's a very common but frustrating situation. Luckily, you can buy a device very cheaply that connects to your cable that will completely alleviate the problem.
Try this ground isolation unit:
http://www.cencom94.com/gpage.html8.html
bri1270
thanks, do you know if that unit will allow for HD to pass through?
bri1270
Got the CISP Yesterday...works like a charm...passes HD without issue.
Thanks
Thanks
Great, enjoy. Keep the link and maybe you can pass it on to others, if I fall asleep at the switch :D
