component cable problem
That definitely sounds like a problem with one of the component cable connections. Since each cable brings in part of the color spectrum one or more being loose, results in lack of those colors. Check the connections at both ends to make sure that they are secure. Try a new set of component cables (really they can be 3 RCA cables). Also make sure each one is matched properly ie as Neil Young sings green to green red to red yellow to yellow. In the dark, its easy to mix up the blue and green cable. If its not that, part of the inner connection must be loose. I almost died when my new DLP projector displayed a bright bluish tinted screen when I was showing it off. Problem, one of my component cables had come undone. Solution, I plugged it back in good and tight. Voila, picture back
