F
ferdie
I used this forum when I was making my decision on which av equipt. to buy
and it turned out to be a really great source of info!
I ended up buying an Epson home cinema 1080 and could not have been happier especialy with the price, 1300.00 plus a free bulb. Having never even seen a home theater setup I was pretty amazed at the picture.
However I had an issue with the pj and called Epson, they had a rebuilt one at my door in 28hrs. Not bad! The problem is with the new pj, on the screen it cast a green tint on the left side about 8 inches by 2 ft on my 110 inch screen, it is only noticable on the dark parts of all the movies. I plan on calling Epson back about this problem, just wanted to know if anybody had any thoughts on what might be happening?
Thank You
BMXTRIX
BMXTRIX
Sounds like a burnt polarizer, which is very much a warranty item if it showed up that way.
F
ferdie
thank you for the info.
I talked to Epson this morning and they are sending out another projector.:D
Again, thank you
