Due to living in a condo, that what I need, to build system around. Small area, 15' by 12'. Speakers must preform great at lower sound levels and also handle occasional higher levels very well also. All ideas will be greatly appreciated. Thanks.
I'm currently breaking in a pair RBH R5Bi speakers in 2.0 mode.
I had them playing at what I would consider moderate volume the 1st day or so, but just to get some hours on them before they get moved to side surrounds I've had them at low volume for nearly 24-28 hrs now.
Don't let the price fool you. (under $250 a pr)...The imaging, and midrange detail equates to a much more expensive speaker and the upper end is not harsh at all. The fit and finish definitely belies the price. I bought these as side surrounds, but with a quality sub I could get comfy with these as mains.
You can spend more and I'm sure come away with a better sounding speaker, but more challenging to do so for the dollar spent.
Good luck with your purchase.
Edited to note...the Philharmonic choice might be better actually, as good for sure.
