Great Samsung 75" 4K TV deal - but only 8bit? Help?
AParsh
AParsh
Hey guys,
So I was about to pull the trigger on a Samsung UN75HU8550FXZA but noticed the website said "8bit" instead of 10bit in the fineprint. I started reading up on differences. From what I'm reading, it seems that for blu-ray 1080p (and even upscaled to 4k) everything should be fine, but I'm getting mixed signals about streaming 4k from netflix and the eventual 4k/UHD blu-ray that will be launching this year. Apparently pretty much all 4k content is 10bit. Will I be able to watch true 4k on this TV if it's only 8bit?
If not, am I able to use a receiver that does support 10bit to push 10bit? What i had read seemed to suggest if the receiver can handle 10bit and the TV has HDMI 2.0 then that should solve the problem.
Can anyone verify?
Thanks.
AParsh
AParsh
For anyone wondering, I called netflix and they said an 8bit 4k TV should still play 4k streamed netflix just fine. But I still am waiting to figure out if it'll be able to play a UHD (4k) Blu-ray or not.
AParsh
AParsh
Blu-ray forum got back to me and said that an 8-bit 4k TV will be able to display UHD Blu-Ray, but will not be able to display HDR.
slipperybidness
slipperybidness
IMO, from what I've been reading, I would want HDR MORE than 4K.
