I was suggested to view this forum by Ron Temple for more information on seperate amps. After a month or so of reading I started shopping.
After reading these threads regarding these $200 to $300 mid line pro amps, I thought I had found the solution to my dilemma.(trying to drive 250w@8ohm with a receiver) So I researched separate amps, and pro amps.
However these $200 to $300 amps turned into $800cnd to $1000cnd.
The only amps I could find in the $400cnd plus tax range where the cheaper brand names such as Alesis, Behringer, Alto. The used ones I found was on their last legs. The darn things had distortion, had lots of floor noise(hum and hiss) or where over $1000cnd. The low-line Crown and the QSC where all in the $599 plus category. The more affordable where the smaller models.
Finding a good affordable amp, with low floor noise, low distortion, and gobbles of power was not as easy as I though.
I shopped the Toronto area during my Christmas vacation. I went to a "high end" store. They had suggested an Ashly ftx-2001 amp. They stated it had the best sound for my application, that they carried. However, It was $1700cnd plus taxes on sale!!!
They sold every flavor of amp thinkable, even HK, Lexicon(starting at $3kcnd,)Merantz.....Crown..QSC..ect......................... ...... yeah, I was drooling...
Next day, I went to a chain Music and Instrument store, and found a used Ashly FET-2000 M, same specs as the Ashly ftx-2001 amp , but for $400 with a 3mth warranty. Instead of asking a sale men to help me, I went straight to the technician in the back. I pumped him for info, without telling him my interest in the Ashly.
After telling him my situation, he steered me to a Ashly amp and a Yorkville studio amp new or used. He said they are the smoothest, most transparent amp out there as a proamp goes, used in a home or studio application. So I picked it up.
It sounds amazing! No hum or hiss even at very low levels. My speakers have more dynamic range and lower details that they lacked. I even have good bass from my mains, combined with my sub placed in the back of the room just went "through" me.The extra dynamic room of this amp was felt right from the beginning.
Simply Amazing!
The mids slightly improved, but the highs did not improve, but sound"ed" Good before the change.
Once my 3mth warranty is over I will replace the fans for whisper quiet ones, However the current ones are quieter than my home computer.
My system:
Athena AS-F2.2 mains
AS-C1.2 center
AS-R1.2 rears
Ashly FET-2000 M
HK 235
LG 7832 DVD
LG DVDRW
15" sub custom box driven by Old Sherwood high current amp
Bell expressvu 6100HD
Hitachi 51S500 rptv
A special thanks to Ron Temple for all the help. My system is finally done...
Well for now anyways.
Here is the spec sheet of the amp.
Ashly FET-2000 M
EIA Rated Output/ch
8 ohms 300W
4 ohms 500W
2 ohms 675
8 ohms mono bridged 1000W
4 ohms mono bridged 1350
THD
1KHz, 8 ohm 0.004%
20 Hz, 8 ohm 0.01%
20-20KHz, 8 ohm 0.05%
IMD (SMPTE) 8 ohms 0.004%
IHF, 8 ohms 0.01%
Damping Factor >100 20Hz--20KHz
Bandwidth 100KHz
Slew Rate 50V/uS
Frequency Response +/-0.5dB 10Hz--50KHz
Rise Time 2uS 10%--90%
Full Power Input Sensitivity 1.7V
Hum and Noise >110dB below full output
Weight 65bs
Here are some Ashly pics of the interior.
http://groups.msn.com/barley/frontdiffoilseals.msnw
