Grandview Projector Screen...
DHolley00
anyone deal with this product name before? what is the quality like?
i was thinking about going with their 92" fixed screen.
what would someone recommend for low ambient light?
lsiberian
lsiberian
I'm not familiar with that brand. I suggest a Carada Brilliant White Screen in most settings. If you want a low cost solution. You can build your own screen with high quality white Black out Cloth fabric stapled on a nice frame. Then you can use some nice felt or tape for the borders. It wont' be a Carada, but hey when your on a budget what can you do.
