Good surround speakers to go with my Boston
matkimje
I have a number of Boston speakers (satellite from the micro 90 series) plus 2 floor ones (V-series).
Due to space limitation where I can put my left and right surrounds (my set up is a 7.1), I need a wedge speaker like that of Boston Bravo II.
My question is if those Boston Bravo II out of my budget, is there any other wedge surround sound speakers out there you all can recommend to go with with my existing Boston. Note, my satellite speakers frequencies is 80mhz-20KH.
Midcow2
Midcow2
Budget ?
How much do you want to spend ? I searched around and found the Bravo IIs at a pretty good price. $114 each, https://usm.channelonline.com/rtech/storesite/Products/Overview/?id=M002220559
I understand if that is too much! Here are good speakers that would work for 4219 per pair dleivered. Cambridge Audio S30 http://spearitsound.amazonwebstore.com/Cambridge-Audio-S30-Speakers-Black/M/B00198LYMU.htm?traffic_src=froogle&utm_medium=organic&utm_source=froogle I have a pair of these and they sound great and are well made and small.
Good Luck!
MidCow2
matkimje
Thanks alot.
Not sure how you did a search for these speakers as I have tried for hours but come up with the cheapest around $150 each. There are other lowers but very low in rating.
$114 is just about the most I want to afford for surround speaker.
One last question there are very few reviews on this vendor R-Tech, and they are not listed as Boston Authorized dealer (meaning the product is not covered under Boston Acoustics). Would you still recommend them?
I believe they are in Canoga Park, CA somewhere in LA and I think I can get to their place to check them out if needed.
In addition, the speakers you recommended below are not really "fit" to the area I will mount the speaker. Only the Wedge speaker can do. How are their sound quality comparing to the Boston Bravo II?
