Good speaker cable for Jamo C809?
Status
Not open for further replies.
Ronchio
Hi. I need suggestion for speaker cables for my Jamos C809. Im using them in 5.0 setup C809 + C80CEN + C80SUR with Onkyo TX-NR1008.
I was looking at Atlas Hyper 2.0 and 3.0, Chord Carnival SilverScreen, QED Relevation and QED Genesis Silver Spiral... but now Im pretty lost in cables. I really dont know what could be good for my Jamos bcs I cant test them.
Maybe you tested some so can you please advice me ?
ski2xblack
ski2xblack
Diy?
Try something of sufficient guage which comes on a giant spool from your local electronic supply wholesaler. They will likely have sheaths and such to make 'em look as fancy as the high dollar cables. That's what I did. Saved a bundle.
I also agree w/ Phillip's Monoprice recommendation; they basically do the finishing work for you, without the audio-hype markup.
Ronchio
Ok guys, tnx for suggestions but I want to know if anyone heard maybe jamos & onkyo receiver with those cables u suggest? Maybe some of you have Jamo C809 speakers so it would be great to hear experiance with these or some "brand name" speaker cables. I know theres disscusion bout them but still I think theres difference in sound with different ones. Right?
All you are paying for with "brand name" cables is the NAME. Speaker wire makes the least difference of anything in your system.
SopRage
SopRage
If there is any difference in sound, it is inaudible to the human ear.
Speaker wire does not have a sound. Just make sure the total resistance of the cable is less than 10% of the impedance minimum of your speaker.
If you pay a lot of money for speaker cable, then you've been played for a fool.
I am not sure why you think it matters which speakers and receivers are used with what cables. It doesn't matter, plain and simple.
zieglj01
zieglj01
It all comes down to the cable inside your speaker - all you need is the
proper gauge to hook up between the receiver and speaker. There is
still the network and cable inside, that feeds the drivers - nothing that
is higher grade will change that.
If something like this will make you feel better - then buy it.
It is less than $3,000.00
http://www.musicdirect.com/product/71992
zhimbo
zhimbo
Wrong, as long as you have sufficient gauge, and the wire isn't faulty in some way, or designed to be "non-transparent" (which, as far as I'm concerned, is just a purposeful way to be "faulty"). Anyone who tells you differently should be ignored.
BTW, if YOU'VE heard a difference, don't worry, it happens to pretty much everyone if the conditions allow it. The difference is in your head only, and is not at all physically related to the wire.
Ronchio
Thanks on all answers! I was just wondering if anyone heard some difference with diff cables with Jamo`s. No answers on that so probably I must assume not.
I know that guy who bought Ferrari wont buy some low budget Pioneer car radio... :rolleyes:
Thats same with cables and HiFi equipment. If someone buy Audio Note Ongaku probably wont buy speaker cable under 500$.
Thats all marketing gimmick for those who have money to spend them.
Money makes the world go round! :D
jamie2112
Seriously all you need is www.monoprice.com for all your cable needs.......10k cable vs $10 cable = same sound, all "audiophile" baloney.........thats why you came here for the truth in audio right?
Ronchio
@jamie
Yeah I came here to see what you guys think about speaker cables and maybe give advice for J. Ok I get the point monoprice!
Tell me... Do you believe in God? If yes... Explain me why other person dont believe?
Why is there many ppl who can hear difference and many others who cant hear? Are those who can hear diff insane?:confused:
Why is there many belivers in God and many others who dont believe? Are those who dont believe insane?:confused:
;) :D
zieglj01
zieglj01
@jamie
;) :D
A little info
http://webcache.googleusercontent.com/search?q=cache:X0-quvrOBtEJ:en.wikipedia.org/wiki/Speaker_wire+speaker+cable+resistance&cd=1&hl=en&ct=clnk&gl=us
KEW
KEW
If you plan to use an Onkyo TX-NR1008 to drive Jamos speakers, this is the perfect cable! Those Jamos speakers won't come alive until you have the proper cable to get the entire signal (as intended by the muscians and Jamos' speaker designers) from the Onkyo to them.
High Performance Onkyo-Jamos Speaker Cable
Accept no substitutes!:D
GranteedEV
GranteedEV
One of these days we're going to find out that the Large Hadron Collider is actually speaker cable for some guy's Hi Fi System.
... and that it sounds the same as monoprice cable.
Rickster71
Rickster71
;) :D
Sounds like you're confusing the laws of Ohm, physics, with that of spirituality.:)
@jamie
;) :D
I sure hope you are joking, or perhaps you are simply a forum troll? :mad: Your question has been more than answered, but you don't like the answer. If you want to waste your money, that is your choice and your loss.
Just because someone BELIEVES something is true doesn't make it true.
Status
