Good receiver < $400
rack04
Good receiver < $500
Can anyone recommend a good receiver for less than $500? A few that I have been looking at include:
Sony STRDE997
Onkyo TXSR601
Harman Kardon AVR230
N
nm2285
I personally wouldn't look at the Yamaha's in this price range. I find them too unrefined and ragged (and a bit bright). I also wouldnt put too much thought in the Sony. Their amps havent really been up to snuff. The Onkyo and the H/K are viable contenders. Also look at the Denon 1800 models (1803, 1804...). You may be able to find a Marantz in this range (the SR4300 or 4400), if so, consider this as well.
U
Unregistered
Guest
You might consider waiting about a month for the Onkyo TX-SR602. Considerable upgrades from what little info I've seen but quite a step above the current 601. Due out in August, but I've not seen any actual press release yet.
Retail for the 600 series is always $499, but you can bet that some online retailers will offer it for $449 right after it comes out.
U
Unregistered
Guest
misconception about yammy's being bright that was the older models .
rack04
I will not be ready to purchase for another couple months so I may check out the Onkyo TX-SR602.
Rex
Rex
Sony STRDE997
Onkyo TXSR601
If you want to spend $500 now, wait and save maybe $200 more and get a really viable Yammie or whatever. Consider the Yammie 1400.
U
Unregistered
Guest
or if you can find deals on last years models a friend of mine picked up the rxv740 for 500 cad
nova
nova
I'd also suggest you stay away from the Sony DE line,.... unless of course you want to buy my DE995 for $400 :)
