Your probably not going to get a lot of answers on this because it's ultimately up to you to decide and you have provided a HUGE list of speakers. All of them are different. Which ones are the best fit for your receiver is up to you and your ears. I think My Bostons work great with my Yamaha 1400 but others may hate this combo.
Do this first. Establish what kind of speakers you want in terms of Towers, Bookshelves, micros, etc. Then, decide how many. 2, 5, 7 or more. Then, start listening to some. Also, remember just because you buy Brand A speakers does not mean you have to buy Brand A subwoofer. There a lot of companies out there that make incredible subs that don't generally make speakers. HSU, SVS, Adire to name a few. A sub is the least important speakers in terms of timbre matching.
By the way, how many speakers are you looking for. If it's more than two, you can probably scratch off Legacy and Martin Logan due to your budget. Damn fine speakers, but bigger mula. Personally, if I had the money, I would be all over the Legacy Classics. They are awesome!
Norrow down your search and then present a new list to us. Maybe then we can give you some pointers. Myself and others could probably write a novel describing all those choices. In the end, go with what sounds best to you. That's what matters, not what myself or anyone else thinks.
Do some listening and get back to us.
Shinerman
