Good link to Wiring and Connectors?
rolyasm
Hello all,
I have multiple questions about wiring, like what wire do I run for RS232 or IR on long runs? Anyway, does anyone know of a link or site that gives some good direction on what wires one needs to run in order to future proof a house. There are so many types of connections/wire, it gets a little over-whelming. Thanks.
Roly
bandphan
bandphan
Hello all,
Roly
cat5e cat5e :D
Midcow2
Midcow2
Yes CAT5 if you really want to future proof CAT6
Bandphan is right about CAT5
Bandwidth precedes data rates just as highways come before traffic. Doubling the bandwidth is like adding twice the number of lanes on a highway. The trends of the past and the predictions for the future indicate that data rates have been doubling every 18 months. Current applications running at 1 Gb/s are really pushing the limits of category 5e cabling. As streaming media applications such as video and multi-media become commonplace, the demands for faster data rates will increase and spawn new applications that will benefit from the higher bandwidth offered by category 6. This is exactly what happened in the early 90’s when the higher bandwidth of category 5 cabling compared to category 3 caused most LAN applications to choose the better media to allow simpler, cost effective, higher speed LAN applications, such as 100BASE-TX. Note: Bandwidth is defined as the highest frequency up to which positive power sum ACR (Attenuation to Crosstalk Ratio) is greater than zero.
What is the general difference between category 5e and category 6?
The general difference between category 5e and category 6 is in the transmission performance, and extension of the available bandwidth from 100 MHz for category 5e to 200 MHz for category 6. This includes better insertion loss, near end crosstalk (NEXT), return loss, and equal level far end crosstalk (ELFEXT). These improvements provide a higher signal-to-noise ratio, allowing higher reliability for current applications and higher data rates for future applications.
Also to future proof, you might want to run shielded speaker wire to every possible locvation youn might ever have speakers. I would use 12 gauge wire. Any larger wire is not needed.
Because DSL uses phone lines , you also might want to run phone lines everywhere you possibly might have a PC, game machine. HT equipment and even phones.
You could run fiber, but the standards keep evolving and the interface is usually pretty pricey. You could run dark fiber to your main Internet and HT and PC locations. But again, in the past in business, the fiber stanard changes and sometimes the runs are obseleted by newer technology.
Running cable in new construction or before drywall is up is relatively cheap.
In summary, run CAT5/CAT6, speaker wire and phone lines obsentsively!
E
Exit
You will probably get some more recommendations at this site, but you may want to look over and possibly post a question at remote central.com under the professional installers forum listed below You could say this is your first installation and you want to do more-the right way. They may help you map out your wiring needs.
http://www.remotecentral.com/cgi-bin/mboard/rc-custom/list.cgi
For my 2 cents worth, I would wire for computer network in each room that may have one installed in the futue (i.e. HT room, all bedrooms, study kitchen, etc.). (The PS3 requires and eithernet versus wireless connection to play games on the internet for example.) I would also run phone line to each of the above rooms for phones, DSL connections and satelite (Dish) boxes. I would also run antenna and satelite dish connections to the above rooms. Some people want cable so I would run that too. These are just a few general things I have run into.
Rickster71
Rickster71
A good bet would be to run vertical conduits in the walls, leading to and/or from the attic and basement.
As wiring needs change, you can pull in a new wire; using the old wire to pull it in.
This helps take some of the guess work out of future proofing.
