good isolation audio rack
thunderbird
Anyone have any suggestions for an audio rack(3-4 shelves) that isolates vibration without breaking the bank... like a Billy Bags brand does? Something similar...thanks
Do you have a cabinet now? What reason to isolate the vibration? Do you have solid concrete slab under it or a raised wood floor? Dowes the wood floor vibrate things when you walk on them now, if that what you have?
You may not have a real problem and any rack will do for you that you like.
sjdgpt
Why the need for isolation?
The components that need isolation, such as the drive system on your CD or DVD player has built in dampening for normal applications (unless the train rolls right by your house every 30 minutes, you are considered to have a normal application).
Turntables are often needing additional isolation.
Unless you have an unusual situation, most off the shelf rack systems, such as those from Sanus, Plateau etc, will do very well.
