Welcome to the forum!
Professional amps give good power for the money, but they don't generally have as good of aesthetics (IMO) as home theater amps. Look at the amp threads on this forum and you'll see a few recommendations.
I'm guessing that you want to use one stereo amp per speaker. Cool. You could also get a multi-channel amp to drive both speakers. As long as you have four channels of amplification, then you'll be good to go. A multi-channel amp will likely take less room than would two stereo amps.
Regarding the power output of an amp, don't worry about having too much - worry about having too little. If the amp is rated higher than you need, then you have some to spare. If it's too low, then you risk damaging your speakers and/or find yourself wanting to upgrade sooner than you thought.
I have two Emotiva amps. One of them works fine (after being replaced), the other not so much. Long story short - the way the company handled it (by simply ignoring me until I went away) will lead me to never do business with them again or ever recommend them. Others here have been happy with them, though, so mine is just one input. There are a number of amp companies out there. I'd recommend also looking at Outlaw Audio.
