Good A/V Rack or Cabinet?
WineOfTheVeins
WineOfTheVeins
Greetings. I am in search of a nice av rack or cabinet that will hold my amp, cd player, etc. but can't seem to find one that is suitable. Any suggestions or recommendations? I like the idea of a cabinet style one that can close to keep it out of sight, secure, and minimal dust. Shelves have to be sturdy and preferably 19+ inches deep. This one stands out, but damn I don't want to spend that much on cheaply made furniture.
https://www.electronicsforless.ca/plateau-lsx-a-41-enclosed-a-v-cabinet-black-oak-5270.html
What do you guys/gals use? Pics would be nice too. Thanks in advance.
BMXTRIX
BMXTRIX
You can take almost any cabinet you want, like this one...
https://www.wayfair.com/furniture/pdp/buena-vista-audio-cabinet-dbhc6988.html
...and modify it to put in rack rail if you want something a bit more awesome inside.
Middle Atlantic standard rack rail is relatively cheap. Under $100. Then you buy shelves which are $30 each (or so) for each of your components. You can get shelves in different depths to handle the gear more exactly if you want. You can get custom rackshelves for about $150 or so each if you are doing a high-end setup, or not. You can get blank panels to fill open areas, etc.
The main thing is ensuring the cabinet is tall enough, and well vented enough, to handle whatever you put in it. Typically having an open back to the cabinet is plenty of ventilation for consumer gear as long is it is not stacked directly on top of one another.
Less than 40 bucks for the rack rail (depending on length)...
https://www.amazon.com/Middle-Atlantic-Products-RRF-18-Spaces/dp/B0002CZVEQ
Shelves are around $30 or less depending...
https://www.amazon.com/AC-Infinity-Cantilever-Universal-Heavy-Duty/dp/B01C9KYUG8/ref=sr_1_3?s=musical-instruments&ie=UTF8&qid=1519327076&sr=1-3&keywords=rack+shelf&dpID=41-04BFuC3L&preST=_SY300_QL70_&dpSrc=srch
Screws will be $13 or so...
https://www.amazon.com/AC-Infinity-equipment-enclosures-cabinets/dp/B01C9N7Z6M/ref=sr_1_3?s=musical-instruments&ie=UTF8&qid=1519327123&sr=1-3&keywords=rack+screws&dpID=51d7KPHvRNL&preST=_SY300_QL70_&dpSrc=srch
So, some pretty cool options if you go that route.
Attached is a photo of one I put in my wall that backs into our closet. Just rack rail, 2x4's, trim, and white paint to make that happen.
WineOfTheVeins
WineOfTheVeins
Thanks for the suggestions. I do kind of like the enclosed wooden cabinets the best, but the DIY rail and lumber method might be an option too. I'm kind of looking at having the cabinet as the centre-piece anyway, no TV equipment or anything else hooked up, just a section of the home with the cabinet in the middle, loudspeaker on either side, and some seating. If I went with the DIY or modular stand, I guess I could drape a blanket or something over it to keep dust away. There's a lot of venting on the top of the Anthem amp and don't want fluff bunnies building up inside.
BMX, wow that looks clean and an efficient use of space! Also keeps dust down to a minimum.
TechGuy, how stable is that unit? I can't help but stare at those toothpick points that plug into one another.
While it isn't enclosed, I saw someone who had made a rack by stacking Ikea Lack tables.
He modified the legs a bit for height/connecting them but pretty easy and inexpensive. Fairly sturdy, guy said he stood on one and he weighed 230 lbs.
3db
3db
I recommend "zline" like unit below. I have one for my main system. The top shelf is 19" deep and lower ones are even deeper. The instructions are well written and its easy to put together. I use one myself.
WineOfTheVeins
WineOfTheVeins
You know; I thought about IKEA as they have cheap furniture, that is a decent idea. Might as well pay a few bucks for pressboard instead of hundreds. Not sure if it suits me though.
3db, thanks for posting pictures of yours. That shelf looks pretty clean and sturdy. Deep shelves as you said are a must, no cords, I have 17 1/2" depth. Dust is one concern, the other is friends and my dog. I'd feel a lot more comfortable if they were all behind a door. We have little get togethers and DJ nights in that room, last thing I need is someone stumbling or spilling schmag on my stuff. They couldn't afford to replace it if they wanted to. :p {Truth}
I do enjoy working with my hands as I am a tradesman. Maybe I can make my own cabinet out of real wood. Maybe buy a couple sheets of G1S Fir or cabinet grade Birch, affix some hardware, stain it, lord helmet's my uncle..
Chokurei
If you are looking for a high quality piece of furniture to store your gear, take a look at Standout Designs. They are expensive, but are high quality, made in America and have unbelievably creative and useful features for cables etc. If your just looking for something to put in the corner for storage, these won't be the answer, but certainly worth a look!
Mikado463
Mikado463
Since I have tubes in my mix I prefer an open shelving, in my case one that I've added a couple hundred lbs of sand /lead shot mix into the legs.
WineOfTheVeins
WineOfTheVeins
I will take a look, thank you for the suggestion!
Thanks for the picture, Mikado. Good idea with adding weight into the legs, I would be very nervous otherwise. Where did you get that tube-style shelving?
Mikado463
Mikado463
The shelving is not necessarily 'tube-style', rather it's just open shelving that is better suited for any type of equipment that requires proper ventilation. As to where I purchased it ......... it been so damn long I forgot, all I know is it's made in Canada, sorry about my old memory !
BMXTRIX
BMXTRIX
...Where did you get that tube-style shelving?
Modular AV racks are the thing to search for on Google. Often they are available with different sized shelving depending on the components you want to use.
A quick search and I got this unit:
http://www.standsandmounts.com/VTIBL304SeriesAVRack-BL304GC.aspx?utm_source=google&utm_medium=cpc&adpos=1o5&scid=scplp19248&sc_intid=19248&gclid=Cj0KCQiA5t7UBRDaARIsAOreQtgu0McTPzM3fYV2fHWzKX1s0UTGye03kCm_RroZqsrzajGhSxsC-6UaAjTGEALw_wcB
It has options for shelves, and I'm sure options on colors.
Mikado463
Mikado463
I'm using their products for my amp stands, I really like the triangle / three leg design, much easier to level.
sterling shoote
I have 3 spare CWD cabinets, like the two end cabinets shown here for sale. If you can make a trip to Louisville, KY you can have 'em for $175 each.
each. These are truly fine cabinets made for very heavy electronics, no sagging shelves.
djembeman
djembeman
There are 2 types that I've found that I'm considering buying. Both are open shelves. I will need 2 to accommodate placing a center tower underneath my TV. Is MDF material better than the glass? There is another small closed one on Amazon, but am concerned about ventilation. These will replace my TV stand. 3 links below.
https://www.amazon.com/gp/aw/d/B01HXN4L6U/ref=ox_sc_act_image_2?smid=A2T4RI5JPP2USG&psc=1
https://www.amazon.com/gp/aw/d/B00797XP1S/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
https://www.amazon.com/Pinnacle-1-Door-Audio-101915-Nexera/dp/B00A0I0CE6/ref=mp_s_a_1_5?crid=3IIWYFRY2RJAH&keywords=av+cabinet&qid=1551436117&s=gateway&sprefix=av+cabinet&sr=8-5
