Seventeen Hz? Your expectations for the SB13 may be unrealistic. SVS only spec’s the sub down to 20 Hz to begin with. Their website shows a graph with response dropping about 12 db/octave below 30 Hz, indicating that the SB13 will get 20 Hz with cabin gain from the typical room. However, your room is 3000 sq. ft., which assuming an 8-ft. ceiling is 240,000 cu. ft. IOW, your room is probably so big it offers only minimal cabin gain, not enough to get 20 Hz, much less anything below that. Bottom line, if infrasonics are what you’re after, you should have gone with one of SVS’s ported options. Or in your room, maybe a couple of them.
Regards,
Wayne A. Pflughaupt
