Hi, I'm a newbie to the forum and pretty illiterate when it comes to AV stuff. I need help! I will try to give a much info as possible about the setup below, and apologies if I miss anything.
We have a Samsung S8000 55 inch TV, and a Harman Kardon AVR 265 amp. Hooked into the amp by HDMI we have a Iomega Director Media Player, DVD player, cable TV, and Apple TV. A single HDMI feeds out from the amp to the TV.
The TV has 3 HDMI in connectors marked - 1) DVI, 2) ARC and 3) MHL. The HDMI from the amp currently is connected to DVI, and we use the TV remote to choose HDMI DVI whenever we want to watch anything that is HDMI connected. The TV also has 3 USB connectors, 2 marked USB (5V 0.5A) and the third marked USB (HDD 5V 1A). There is also a Digital Audio Out (Optical) connector in the TV, and 2 in the back of the amp.
There are no issues with any of the above, until I try to play from a USB source, either a stick or a Seagate 5GB expansion drive that I use to store movies etc. The expansion drive has no HDMI connector. It connects to the TV through a USB, and is currently connected into one of the 2 USB (5V 0.5A) slots. We can only get volume through the TV speakers. To watch anything on the expansion drive we change the source to USB expansion drive. The interface for accessing the content is Samsung Link.
The question is, how to we get the sound from the USB source to play through the amp like all the other devices?
A friend said it was as simple as running an Optical cable between the amp and TV, but I got nothing there - I tried 2 cables to see if it was a cable problem, and I couldn't find anything in the amp menus about optical sources, so I am not sure if it is a setting issue.
Another guy said I just had to run the HDMI from the amp into the HDMI ARC connector - again, nothing.
So, it would be fantastic if someone could help me crack this issue once and for all.
Thanks in advance!
