Stryf3 said:
This may be a dumb question, but did you select DTS 6.1 in the DVD menu? It sounds like the rear center is being matrixed from the left and right rear channels.
Stryf3, thanks for your reply.
Yes, the DTS 6.1 is selected from the menu as a result the Surround Back Speaker has sounded. However, the Amp's panel doesn't display the SB speaker. Is it my Amp's problem or set up problem? I just bought this Amp 1 week ago.
My FL, FR, Central, Woofer, SL & SR are displayed on the panel except SB while playing DTS 6.1 although there is sound from SB speaker.
Hope I'm not getting a faulty unit, if it is fault, I'll need to return back to them. HELP!!!!
