Have upgraded my home theater to 4k and not happy about necessary upgrade to get my 4k to new tv.
Want to continue to use my Parasound 220W/channel x5 power amp (2205A) but hate to spend 700-1000 minimum to upgrade my Emotiva UMC-200 processor. I have two home theaters, so anything I do is times 2.
The least expensive upgrade is a full blown singing and dancing AVR with pre-outs for about $500.
But if I don't use pre-outs, I can get a low-profile AVR that will fit in my cabinet, like the RX-S602 reviewed on this site.
I just don't pay attention nor listen close to "theater levels" when watching videos...so not terribly concerned about quality.
Listening to music is a different story. Very picky. I am thinking about passing digital optical PCM 2-channel out from AVR to an external DAC that has volume control (wyred4less?) and auto-switching the line level L-R sources for this to my power amps when listening to music.
************** THE QUESTION ***************
Can I fake multichannel outputs by using resistor dividers on those AVR's speaker level outputs? And if it is even feasible, how big a hit on audio quality could I expect. I am assuming modern amps will not destroy themselves with a high impedance load (or open circuit). I certainly do not want to simulate speaker loads at 8 or 16 ohms and create heat with high wattage resistor loads. Yes, I know these amps are designed for complex impedance loads, but, but....
Speakers are B&W 805's (and matching center model). Left and Right channels have an line-level active Linkwitz-Riley crossover (Hsu) that passes LF to a pair of Hsu ULS-15's and feeds the 805's 90Hz+. Suspect my 220Wx5 Parasound is way overkill in that arrangement. Leftover from floorstander days, it is an 85 lb emotional attachment (like my dog).
