I have a 5.1 with Bowers & wilkens 705 bookshelf Speakers in the front. In Ceiling Proficient in rear. I do not remember the model, but the higher end ones for home theater.
A denon avr 2312 to drive them. I was wondering how to get great sound out of these beautiful speakers without breaking the bank. I have access to marantz, denon, yamaha at some discount.
I am not sure of bi- amp wiring, to amp drivers separate from tweeters. I guess some of the issue might be power, but I believe it could also be speaker placement ( now they are , room, EQ, crossover? I also have a subwoofer, set the speakers to small, crossover at 80Hz.
What is different about higher costing receivers? Would Bi Amp help? If you Bi Amp what do you use?
All my gear is about 40 feet away in a closet. I am using decent 14 gauge audio wire, a bit better than standard wire, for the front speakers.
The left and right speakers are 14 feet apart.
I feel I am not getting anywhere near the speakers potential. I don't always want it loud, sometimes, but I do want some options.
Using uncompressed wireless iTunes, Sony BD S 585 Bluray, and DTV Satellite.
