I know this isn't the right way to do this, but I will be constantly moving between untreated rooms, and I don't have money to treat all of them. I don't care about aesthetics. I just want the best improvement to cost ratio treatments that can easily and without harm be moved from room to room. I have 60-80$ to spend right now. What should I get?
ATS Acoustics Rigid Fiberglass Board
Is that good, and can I get for cheaper somehow if it is? Would I need anything else beside that? Fabric? Frame? Should I do something else completely?
Thanks so much for you time! : D
BEST WISHES!
