So I pretty much have no idea what I'm doing when it comes to setting all of this up.
I recently purchased
2 Pioneer FS52
1 Pioneer C22
2 Pioneer BS22 (not hooked up yet because I have no room for them)
1 BIC America F12 sub
Denon 1912 receiver.
What should I do as far as volume levels on the sub as well as in the receiver, crossover frequencies, etc.
I have no audyssey mic and some people have said they didn't prefer it over manual setup. I just want to get the most out of the speakers and have them blend well but I have no idea what I'm doing.
I know how to navigate the receiver so I'm basically just curious what I need to do to maximize the sound. It currently is set up in a 3 walled room in one corner, facing the opposite corner.
Room dimensions are 15x15x9 and I know the acoustics make a difference but I'm more concerned with what I should set crossovers at, and should I raise levels on certain speakers and lower others. Volume control on the sub itself, full, half, 3/4?
Thanks for all your help
