I just picked up a Garrard 770 turntable for a whopping $5, but it doesn't seem to be working. I was told that it worked, and that I could return it if I wanted. The platter is very stiff, but turns smoothly with a little force. I'm not sure if that's because its direct drive and not belt. The motor doesn't spin up at all. Any suggestions of where to start? I opened it up and there's nothing visibly broken.
It appears the speed selector is jammed, and for some reason that's stopping up the whole motor. I could hear the motor briefly when I tried to change the speed
Your
Garrard 770 turntable uses the synchro lab motor and idler wheel drive.
First remove the platter. remove, or push aside the idler wheel and see of the motor works.
Take it from there.
In all honesty these Garrard turntables are not very good.
The only Garrard turntables that are any good are the 301 and the 401. These are very good.
Garrard where the Crown jewelers. The directors from the dawn of record reproduction set up Garrard turntables at Swindon Wiltshire.
They produced basically junk and one very high end product through out their history, until going broke from the Far Eastern onslaught.
They sold all 301 and 401s at a loss, subsidizing them from all the junk turntables. The whole approach was unashamedly cynical.
They were acquired by a Brazilian outfit who produced the lowest of the low before going broke.
Loricraft started refurbishing 301s and 401s and finally obtained the rights to the Garrard name. Now in addition to restoring and refurbishing 301s and 401s, they produce the Garrard 501.
As you can see from their website, they will have absolutely nothing to do with Garrard turntables other then the 301, 401 or 501. They will not even answer inquires about other models and do not supply parts fro them.
If you need an idler wheel there are places to have custom ones made. For other parts, other than striking it lucky on eBay, you will be out of luck.
