So...the game room is under construction. It will have an area for pool table, a bar, and an area for TV/Games/Movies. The part of the room for the TV/Game area is about 18' wide by 18' deep (open in back to bar and pool table area).
square dimensions are the worst possible for acoustics. just fyi.
I've decided on the TV -- Panasonic Plasma TC-P65V10. I'd like any advice on what to buy in the following areas:
Great TV. I personally vote plasma over RPTV if only due to reliability. The latter type might represent the highest failure rate, at least according to one pro here. Then you have the PQ improvements too. If you can befriend someone who works for Panasonic, the family/friends going price right now is $2,400.
Speakers? prefer in-wall, but confused about where to buy and type
Your money doesn't go as far when buying in wall, as far as SQ. Just fyi.
But, since the speakers ARE going to be hidden, I'd set it up for 11.2! After all, you should be able to afford a bunch with your budget, with Speakercraft being the selected brand. (not $$$ as with Triad or James). Check out Audyssey DSX capable receivers. The ones that can do height AND width channels simultaneously won't be cheap, it appears.
DVD or Blu-Ray? which one to buy?
Of course, bluray. Bluray players play DVD very well, in fact better than most dvd players.
ONLY bluray movies: Panasonic bd60, $170.
For gaming too: Sony slim ps3 $300
No gaming, but for audiophile, Oppo $500. (gets you faster load like with ps3, better dvd playback than pana/ps3, but that difference will be just about negligible after you see your first BD).
We'll have a Wii, Xbox 360 and HD-Tivo (and cable)...plus an internet connection at the TV. Kids will probably add more music and games in the future, possibly PS3
Oh. Just get the ps3 now. I would most definitely consider adding a warranty to a gaming console, and I almost never buy warranties. good luck
