GAIN VS POWER - DROP AMP N' DAC INFO NEEDED
johnny45
johnny45
is the 6watt output constaint in balanced mode for the DROP + THX AAA™ 789 LINEAR AMPLIFIER or is it less at lower gains to anyone who know what the power level output is at Gain: 0.66x , 2.0x i want to give my m570 cans sound good power an sound
but not blow them out i plan to put a Peavey PV215EQ Graphic Equalizer between it an my DROP + GRACE DESIGN STANDARD DAC BALANCED i really hate pc software eq's
just never quite right an can i add the amp an dac to the cart at the same time
G
Gmoney
why would you care about the v output? what's you point of inputting a EQ in between your gonna DJ a Party or at a club, you do know this is a Home Audio Forum. Maybe some members will chime in only because some use those cheap amps, pro amps as Opposed to a more refined home use audio amp. May want to post up in one of AH other Forums that's about Software are use off, since you seem to be trying to Incorporate it into your system it does help with Streaming or what ever PC your using For your source.
