Yes, I’ve had it every time I’ve had an. MRI. My first was in 2019 also to look for prostate cancer. It identified my case and in about a year I had it removed. Five years later, and still no more prostate cancer
Nearly a year ago I was diagnosed with advanced lung cancer. A head MRI in Nov 2023 found 4 spots of metastatic lung cancer in my brain
. I had more MRIs as follow up, in Feb, July and another in a few weeks. Those 4 spots have vanished
. The drug I take works!
All those MRIs used that same contrast agent you will get. I never had problems with it.  So don’t believe everything you read on the internet. They may be true, but they are not common.
Some people are allergic to the contrast dye, so radiologists do have experience when it’s not used. From my own experience, I think you should get it. Ask about that. You probably don’t know if you are allergic to it, but ask anyway.
MRI scanners are SLOW and VERY LOUD. My brain scans take about 45 minutes! Definitely wear good ear plugs. Look on Amazon for Mack’s brand.  I have the basic compressible foam kind.  You will thank me later.
The scanner’s tunnel is close to you. I can’t remember during my prostate scan if my face was inside that tunnel, but it was inside it for brain scans. If you get antsy in close spaces, bring a sleep mask and wear it. Look on Amazon. I find I stay relaxed during those long & loud MRIs if wear ear plugs & a sleep mask. Again, you can thank me later.
Good luck! And let us know the results. Both I and others like TLS Guy have gone through prostate cancer, with success. I had surgery, he had proton radiation, and we’re both still here.
