How would DC flow in a transformer when the power grid is non-rectified AC?
Also, how much filtering does a power amp really need? If the line voltage exceeds a certain level, I would hope a breaker or other protection device would open, somewhere. Obviously, the big amplifiers that are designed by people who are still striving for "straight wire with gain" and use nothing to protect anything might have a problem at >180VAC, but that's not common unless a transformer melts down or lightning strikes nearby, right?
After attending a Furman session at a distributor's open house, I spec'd a Furman Elite 15PFi in 2007 and none of the equipment has had any kind of problems from electrical issues, including lightning. I was in the room where the rack is located when lightning struck outside of the house as I was checking some of the remote control changes and when I saw the flash, I heard a loud 'snap' sound inside the room. I looked around and noticed that the ADT cellular module's "call for service" light was flashing- the antenna is next to the copper gutter at the 2nd floor roof line and it's not grounded. The power amps are powered by this unit but they don't draw a lot of current and I'm using one of the 'Amplifier' receptacles to power one for the 12VDC trigger and the other is un-switched, but the Mac amp has its own 12V trigger.
However they do it, this has worked flawlessly for almost 9 years.
