Furman Elite-15 DM i 13-Outlet question
Status
Not open for further replies.
JDmsz
I just bought Furman Elite-15 DM i 13-Outlet a couple days ago and why all the outlets don't work unless it's on bypass mode?
Also I see a Remote Turn On indicator. How do you configure that?
WaynePflughaupt
WaynePflughaupt
None of this is covered in the manual?
Regards,
Wayne A. Pflughaupt
By chance did you try calling the company?
No it's not that serious I just figured one of you guys would know since it's a popular choice of a conditioner.
Well, it is important to know and bet that not too many here have that product.
You either did not read the manual or English is not your first language. It is VERY clear in the manual. The outlets are divided into 12 volt triggered and non triggered groups. When you press the bypass mode, only the 12 volt trigger is bypassed. So if you press bypass all outlets work without a 12 volt trigger.
The remote indicator light is just to tell you when outlets have been made active by remote 12V trigger.
You know you really should read a manual before purchase, as otherwise you have no idea if the unit is suitable for your needs.
You have bought a unit without understanding its basic core operating functions. You get the tstoe award of the week for that.
everettT
everettT
The time to ask questions is prior to purchase, so when you do your well informed. Are you going to use the triggers? If not return it and put the money towards a better purchase for your system. I believe your still not using that great of subs, correct?
JDmsz
I have two svs sbnsd subs but I just use the auto on feature.
Status
