Funkywaves LMS5400 with the S8's finally!
Docks
Links at bottom.
Equipement used
QSC CX404 - biamped
Behringer EP4000 - bridged
DEQ2496
DCX2496
Sub - Funkywaves FW18.0 using LMS5400
Speakers - Paradigm S8's
*Future PC Active XO, Phase correction, Better Room EQ to come*
I wanted to thank Nathan from Funkywaves and several forums including this one for the great ideas.
I have pretty much unlimited power handling for any kind of volume i can bear =/
GranteedEV
GranteedEV
Is that really a good spot for the sub? In my room the front center of the room like that is awful! I'd much rather offset it to 2/3s into the room or something.
Congrats!
What you'll find, is that the bass just doesn't change character no matter how loud it really is. Some subs sound good at everyday levels, this one one sounds good at any level, right?
Docks
The sub is amazing at all volumes that my house/myself can bear.
I'm not sure if its the driver and the fact that its sealed, but it sounds very true to the source. Its amazing how it can sound so accurate and punchy in critical music but still play drum and bass without a problem.
It sounds very good where it is, Ill have to do a few more tone sweeps and measurements in a few weeks, would be interesting to see the in room response and if there is any nulls. I did a quick sweep last night and never noticed so far, I plan to look for them.
GranteedEV
GranteedEV
It's the driver. First of all it's an 18. It barely has to even move to produce more output then most people's subs at full tilt. And needs less watts too. It's around 90db sensitive in its upper range. Most 12" drivers designed to dig deep, are closer to 84db sensitive. Less heat means less thermal compression (a form of distortion)
Second it's an LMT driver. These drivers use a variable density voice coil that means the magnetic field of the motor barely if at all changes no matter how far out the driver has moved. Less variations in this respect, means less throw-based compression (another form of distortion)
Third it's a driver with well placed shorting rings. This keeps its induction curve well under check which again just flat out means low distortion. With shorting rings, you're not hearing much if any intermodulation distortion between deep notes and other notes muddying up the sound. Every note is distinct and clear.
Fourth it's the watts. You've got a ton of them on tap if the signal calls for it :D :cool:
Finally, because it's got a typical sealed rolloff, it's probably coupling well to your room and listening preferences. Doesn't mean that can't be reproduced with a vent or transmission line, but it'd take a more intricate design and EQ approach. Sealed is simple, and it's smaller too :)
You flat out picked a great sub. Now it's time to get two more :eek:
baniels
baniels
I'd love to see some closer shots of his craftsmanship. His work is nothing less than spectacular.
Warpdrv
Warpdrv
Click my link below.... I got really good shots of mine. post 98 & 102
Docks.... Congrats - best sub money can buy !!!
Now raise the crossover up to 100-120hz and crank it... Don't let your ego get in the way even though the S8's have all those bass drivers in the S8's deterring you from the INCREDIBLE performance of the LMS in the same upper bass band region - it'll blow you away.
With your sub placement you should be getting great radiation patterns depending on your room dimensions. Keeping localization to a minimum. What size and what are the dimensions of your room ?
Thats a bad combination, S8's & LMS.... :D
I really like the Be tweets - not as much as the RAAL on my Salks but very very smooth... No question that the LMS is an incredible addition to your mains.... Music should sound far better now...
PS..... get rid of those soda cans and grab yourself a booze !!!! You've earned a celebration !! :)
Beatmatcher247
Oh this thread is giving me upgradeitis. lol.
