$120 obo, prefer local pick-up in So. Cal., if not buyer pays shipping. 30 lbs. ea. w/o boxes. have manual.
The specs:
Wharfedale Rubiance RB-25 Overview:
High density, pressed mineral homopolymer cones driven with double, hand wound voice coils are secured to the front baffle with our special alloy retaining rings. This helps keep the bass tight and controlled, even at high volume levels with very low distortion levels. Our famously smooth tweeters are well represented in the Rubiance with a 25mm textile dome unit extending the frequency response well into the inaudible spectrum. This ferrofluid cooled unit has rear venting to reduce dynamic compression and offers an incredibly flat response.
Function System Nominal Power 100 Watt RMS Construction 2-Way Cabling Cable Frequency Reponse 42 Hz - 20,000 Hz Sensitivity 88 dB Impedance 8 ohm Bi-amping Tweeter Size 1 " Woofer Size 6.50 " Floorstanding Terminal Binding Post Exterior Color Black Width 8.66 In. Depth 10.94 In. Height 33.62 In.
These speakers really are in perfect condition. No tweeter damage, no cabinet knicks as they have had minimal use. These speakers produce a very neutral sound thats perfect for types of music. And they go suprisingly low given the cabinet volume.
For the pics: (hope they work, 1st time uploading on this site)
be sure to see my other items!
