FS: SVS SB12-NSD - Excellent
tn001d
tn001d
For sale is a like new condition SVS SB12-NSD subwoofer. This model falls between the SB1000 and SB2000 in terms of performance. It was never pushed hard and was used in a secondary system with limited use. It is in excellent condition and is packed in the original packaging.
$400 Shipped Continental US
Frequency Response / Acoustic Data:
23-270 Hz +/- 3 dB
2-meter ground plane away from reflective structures (quasi-anechoic)
Subwoofer Specs:
Premium black ash finish
Front-firing 12" driver
Rigid Medium Density Fiberboard (MDF) cabinet
Protective non-resonant steel mesh grille
Detachable 8 foot power cord
Cabinet Dimensions: 14.2" (H) x 14.2" (W) x 14.2"(D)
Overall Dimensions: 14.7" (H) x 14.2" (W) x 17.3"(D) (includes feet, grille, amplifier)
Weight (unboxed): 35 pounds
Shipped Dimensions: 21" (H) x 20" (W) x 22"(D)
Weight: 51 pounds
Driver Specs:
SVS 12” NSD driver
2” diameter, high-power voice coil with high-temp former
Nomex linear roll long-throw spider
Low-creep rubber long-throw surround
Spider-integrated tinsel leads
Aluminum cone and composite dust cap with SVS logo
Powder-coated cast aluminum basket
Finite Element Analysis (FEA)-optimized motor structure
Dual shorting rings and pole extenders to reduce gap induction and distortion
Dual high-grade ferrite magnets
Amplifier Specs:
STA-400D Sledge with 400 watts RMS continuous power (800 watts peak dynamic power)
High efficiency cool-running Class D switching topology
Detachable power cord with main power switch and fuse
RoHS compliant, lead-free construction and world-wide safety certifications
Auto-On / On switch with "green" standby mode
Stereo line-level RCA input/output connections
Fully adjustable low pass filter with Disable setting
Unfiltered (for daisy-chain) and 80 Hz HPF line level RCA outputs
Customized EQ and DSP limiter settings specifically for the SB12-NSD
Input impedance - 20 kΩ (unbalanced RCA)
afterlife2
afterlife2
Wow Great deal! Should go fast! Good luck on sale. Try Craigslist too.
Pandaman617
Pandaman617
Hey I’m very interested in this, I sold mine a few months back to a user on here and am regretting it. I just bought a C1 OLED and an Emo Pre/Pro & Power amp so I would have to wait until I get paid next week but if it’s still here I’m definitely interested
tn001d
tn001d
Available , but receiving lots of interest on marketplace
tn001d
tn001d
Get it now for mothers day !!
afterlife2
afterlife2
Maybe you should mention warranty. Any left?
