I have a pair of excellent condition Revel F328Be Performa Tower speakers in Walnut finish for sale. These were used in my music room for the last 3+ years and are in perfect working order.
MSRP: $17,600/pair
My Price: $8,500/pair - local sales ONLY (Tampa, Florida) - cannot ship.
Specifications & Key Features
- Type: 3-way, 6-driver floorstanding loudspeaker
- Frequency Response:
- In-room: 26 Hz – 40 kHz
- ±1.0 dB (on-axis): 35 Hz – 26 kHz
- Recommended Amplifier Power: 50–350 watts
- Impedance: 8 ohms nominal
- Sensitivity: 90 dB (2.83V/1m)
- Crossover Frequencies: 280 Hz, 2.1 kHz
- Enclosure Type: Bass-reflex via rear-firing port
Dimensions & Weight
- Height: 50.2 in (1275 mm)
- Width: 14.1 in (359 mm)
- Depth: 16.2 in (412 mm)
- Weight: 113.5 lbs (51.5 kg) per speaker
Drivers & Materials
- Tweeter:
- 1-inch (25mm) Beryllium dome
- Integrated waveguide for dispersion control
- Midrange:
- 5.25-inch (130mm) Deep Ceramic Composite (DCC) cone
- Cast aluminum frame
- Woofers:
- Three 8-inch (200mm) Deep Ceramic Composite (DCC) cones
- Cast aluminum frames
DCC (Deep Ceramic Composite): A proprietary cone material offering high stiffness-to-weight ratio and excellent damping, reducing coloration and distortion.
Here are the CTA-2034 measurements for the Revel F328Be:
Performance Overview
- Sound Signature: Neutral and transparent, with a wide soundstage and pinpoint imaging.
- Bass: Deep, controlled, and extended, thanks to the triple 8" woofers.
- Midrange: Smooth and uncolored, with excellent clarity.
- Treble: Airy and highly detailed, courtesy of the Beryllium dome tweeter and its precision waveguide.
- Dynamic Range: These speakers play very loud and clean but trade some deep bass extension for higher sensitivity. They work great for home theater applications when paired with potent subwoofers at their performance level.
Ideal Use: High-end stereo listening and home theater setups. Pairs well with high-power solid-state or tube amplification.
PM me if interested.
View attachment 73065View attachment 73066View attachment 73069View attachment 73068View attachment 73070
