FS: QSC KW181 Subwoofer
s91
Hello,
I'm selling a QSC KW181 Subwoofer, it is suitable for reproducing crisp and clear sound.
This 18-inch active powered subwoofer features a 1000-watt Class D power module. It has a frequency response of 39 Hz to 145 Hz.
Handling and moving it is easier with the conveniently placed ergonomic handles on the sides.
QSC does not make this speaker any longer and used ones in decent condition are getting harder to find at reasonable prices. It fits your needs.
Color: Black
Connectivity: Wired
Features: Portable, Casters, Input Gain Control, Amplified
Type: Subwoofer
Weight: 120.2lbs.
Depth: 22in.
Height: 36in.
Width: 28.7in.
Item Weight: 40 kg
Price is $3,250
Send me a PM or email if you are interested
iansas91(at)gmail.com
The QSC KW181 is the best choice. They are loud and very clear. They give you a tight thumping bass that your looking for to complement the QSC K12's.
These are by far the best sub's i have herd, and with the caster wheels it make moving them so easy. Love them and would highly recommend them to anyone looking of powered subs.
Have a great day and thanks for your time...!!!!
