FS: Pioneer SX-1250 stereo receiver
all1
For sale is a vintage Pioneer SX-1250 stereo receiver, this is in perfect working condition.
This Pioneer was built in the golden era of audio and lives up to that reputation flawlessly with an incredible phono stage, impressive clarity, a whooping 160 watts per channel, and a robust design that has and will last for decades to come.
Specifications:
Tuning range: FM, MW
Power output: 160 watts per channel into 8? (stereo)
Frequency response: 10Hz to 50kHz
Total harmonic distortion: 0.1%
Damping factor: 30
Input sensitivity: 6.5mV (mic), 2.5mV (MM), 150mV (DIN), 150mV (line)
Signal to noise ratio: 75dB (MM), 90dB (line)
Output: 150mV (line), 30mV (DIN), 1V (Pre out)
Speaker load impedance: 4? (minimum)
Dimensions: 556 x 186.5 x 464.5mm
Weight: 29.2kg
"When you go to buy a new receiver, ask yourself these questions:
Does its FM tuner section guarantee high performance of spurious rejection as well as high sensitivity?
Does it include the very latest electronics circuit technology to assure a constant stable and high quality sound reproduction from small to large power output?
Are you going to be proud to own it for a long, long time?
Pioneer's new and elegantly designed SX-1250 AM/FM receiver provides a resounding yes to each of these questions - and then some.
No other Pioneer receiver provides such incomparable FM performance and sensitivity and then combines it with mammoth continuous power output of 160W per channel, min RMS at 8 Ohms, from 20 Hertz to 20,000 Hertz, with no more than 0.1% total harmonic distortion."
Overall in fantastic shape and excellent working order.
Asking $3800 USD
If you are interested kindly contact me via PM or email
allsales at protonmail dot com(Remove the space)
Thanks for looking...!!!!
