Fs: Pioneer Elite VSX-TXV72 Reciever With Hdmi Switching/transcoding Thx Select 2
Z
zoran
Brand New Full Warranty. Decided To Go With 74txvi.
$999
Pioneer Elite VSX-72TXV Specifications
Power
Power Amplifier Design Direct Energy
Surround Power 130 W x 7 (20HZ - 20kHZ @ 8 ohm, 0.09% THD)
Stereo Power 130 W x 2 (20HZ - 20kHZ @ 8 ohm, 0.09% THD)
Digital Decoding & Processing
Digital Engine Sharc-EX + 48 Bit Motorola
Dolby Digital 5.1 Yes
Dolby Digital EX Yes
DTS 5.1 Yes
DTS-ES Discrete 6.1 Yes
DTS 96/24 Yes
DTS NEO 6 Yes
Pro-Logic II DPL IIx
Windows Media Audio 9 - Professional Yes
THX Yes (Select 2)
Air Studios Tuning Yes
Surround EX Yes
Pioneer Original Surround Modes Advanced Surround 6 Movie / 7 Music
Virtual Surround Back Yes
Midnight Listening Yes
Loudness Yes
MCACC Yes
Speaker Configuration Yes
Speaker Size Yes
Speaker Level Yes
Speaker Distance Yes
Acoustic Equalization 9 - Band
Advanced MCACC New
Phase Control Yes
Standing Wave Control Yes
Room Acoustic Status 3-D Display via PC Yes (Pre & Post Calibration)
Analog to Digital Conversion 96 kHz / 24-Bit
Digital Analog Conversion (DAC) Burr Brown DSD1791DBR - 192 kHz / 24 - Bit
Connectivity
Ready for iPod Yes
XM Ready Yes
Analog Audio Inputs 10
Analog Audio Outputs 3
Digital Inputs 7
Optical In 5 (Includes 1 Front Input)
Coaxial In 2
Optical Digital Output 1
Multi-Channel Input 8 Channel
Audio Pre-Output 8 Channel
Composite Video Input 7
Composite Video Output 3
S-Video Input 5
S-Video Output 3
Component Video Input 3
Component Video Output 1
Video Conversion Yes - Digital To HDMI
Video Adjustments Yes
Video Signal Select Yes
Component Video Frequency Response 100 MHz
HDMI Inputs 2 (HDMI connection may not allow transmission of copyright protected material depending on the capability of the signal source)
HDMI Output 1
Headphone Output Yes
Multi-Room and Source Output 3 Zone - Main, 1 A/V, 1 Digital Audio
12 Volt Trigger Yes x 2
Front A/V Inputs Yes
IR IN/Out Yes
RS-232C Yes
AC Outlet Yes
System Remote Control Port Yes SR+
SP Terminal Type Banana
Speaker A/B A/B, A+B
Adjustable Speaker Configuration Yes (2nd Zone /SB Channel / MR&S)
Convenience
On-Screen Display Yes (HDMI OSD 480i only)
Dot Matrix Display Yes
Remote Type LCD
Pre-programmed Yes
Learning Yes
Macro Commands Yes
Construction
Front Panel Aluminum
Transformer Stabilizer Yes
Direct Construction Yes
Warranty
Terms 2 years parts and labor
Dimensions
Width x Height x Depth 16 9/16 x 7 3/8 x 18 3/16
Weight 35.1 lbs
Z
zoran
brian32672 said:
I am thinking of upgrading (will sell my 1015tx). But I may wait for them to come down a little.
Unless you can match or better these 3 companies on the 72???
http://www.allhometheater.net/PIONEER-ELITE-VSX-72TXV-P17863C0.aspx
Also
http://www.plasmawholesale.com/itemdesc.asp?ic=VSX72TXV
Also
http://www.plasmahouse.com/PIONEER-VSX72TXV-PLASMA-TV/VSX72TXV.HTML
sorry, these 3 companies seem same sharks with different names..lol.
It will be beneficial for me to return and get my money refunded from authorized dealer!
howie85
howie85
Food for thought Good Guys going out of business 10-30 percent off currently the pio elite is at 10 could go up from there I was thinking about using that as price match material at my local bb/magnolia has the 74 for 1499 currently.
T2T
T2T
brian32672 said:
Yeah, that may be. Because I don't think the warranty is transferable.
Actually, Pioneer Elite is one of the warranties that can be transferred - Provided, the item was purchased from an authorized seller the first time around. :)
