FS: Klipsch Quintet Sat's
Paulio
FS: Klipsch Quintet Sat's/SOLD
SOLD
One pair of white sat's from a Klipsch Quintet set up.
Will ship at buyers cost, actual shipping cost only.
Pics on request
Asking $75 for the pair O.B.O
Please email directly if interested
p.jasek@comcast.net
QUINTET SATELLITE II
FREQUENCY RESPONSE:
100Hz-20kHz±3dB
SENSITIVITY:
90dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (200 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Bass reflex via rear-mounted port
DRIVE COMPONENTS:
Two-way system using one .75" (1.91cm) magnetically shielded, polymer dome compression driver tweeter with a 90°x40° Tractrix® Horn and one 3.5" (8.9cm) magnetically shielded, poly cone woofer
TWEETER:
K-127-N 0.75" (1.91cm) Polymer dome compression driver
HIGH FREQUENCY HORN:
HF CROSSOVER:
4900Hz
WOOFER:
K-1069-KV 3.5" (8.9cm) Poly cone
DIMENSIONS:
7.5" (19.05cm) x 4.25" (10.8cm) x 6.375" (16.19cm)
WEIGHT:
4 lbs. (1.8kg)
ENCLOSURE MATERIAL:
Stone Mineral Compound
FINISHES:
Black, White, Silver
YEARS BUILT:
1998 -
