Hello
Clearing out some equipment I no longer use
Klipsch KSW-12 SUB
Like new, Excellent condition
Have original carton and manual
$300.00 plus shipping
p/m or send email to
hv9200@comcast.net
paypal preferred
Specs
frequency response 26Hz-100Hz±3dB
power handling FTC Rated Power: 105 watts continuous,
22-100Hz @ ≤ 1% THD
Dynamic Power*: 440 watts @ ≤ 1% THD
*Dynamic power indicates the actual power this amplifier will deliver to the woofer under normal operating conditions. While the FTC power rating indicates power available on a continuous, long-term basis, subwoofers do not rely on that type of power. Instead, the amplifier is called upon to deliver large, short-term peaks of power to be able to support the wide dynamics required by today's digital music and movie formats. In addition to the required FTC power rating, we've provided the dynamic power rating as a better indication of the product's true performance.
sensitivity 113dB SPL 1/8 space, 1 meter
low pass crossover Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
woofer K-1071-K 12" (30.5cm) down-firing fiber-composite cone
amplifier Class A/B discrete MOSFET outputs
phase Switchable 0 or 180 degrees
enclosure material MDF enclosure type Bass reflex via rear-mounted port
outputs 2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
inputs 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
auto power on 2 Second ON delay, 15 minute OFF delay
dimensions 17" (43.18cm) x 15" (38.1cm) x 15" (38.1cm)
weight 35 lbs. (15.9kg)
