FS: Integra MZA 4.7 Multi-Source/Multi-Zone Amp
adk highlander
adk highlander
Sith Lord
I've been making some changes in my house setup and have decided to sell the heart of my old system.
The MZA is a 4 zone 8 source distribution system. The 4 zones have both pre-outs and built in 50wpc amps. It is PC programmable and it can be controlled via PC (USB or RS232), IR (in and out) and RS-232.
It has a Party Mode to have all zones play the same source and an alarm function to start up at a preset time.
Here is a link to the Integra page to download the manuals and software: LINK
I will also include 2 Key pads. 1 Key 2.7 and 1 Key 5.7. These have both IR learning and will act as IR receiver to pass IR to the main unit for distribution to the sources. Single Cat 5 wire is all that is needed.
They Key pads are in link new condition and the MZA is consmetically in very good condition. There may be some minimal scratches on top from other sources sitting on top. The only functional issue is the the LED light on the front panel flickers when a zone is powered on. This was always out of site for me so it never bothered me and does not have anything to do with the functioning of the unit.
I will take pics tonight but for now here are stock photos:
Front:
Back:
Key 5.7:
Key 2.7:
Back installed in my rack:
Amplifier
50 Watts RMS at 8 ohms
4 Amplifi¬ed zones- expandable to 32 zones
Stable into 6 ohm loads
3 Progressive levels of thermal protection and control
Level 1
Level 2
Level 3
Protection against short-term output shorts
Front panel clipping indicators for each zone
Amp On status indication
Maximum volume setting by zone (amp or preamplifier outputs)
Preamplifier
7 Stereo sources, 1 mono source (typically for paging application)
8 Source composite video switcher
Bass, treble, balance, & loudness control by zone
Output levels can be set independent of ampli¬er or set to track w/ ampli-er
Miscellaneous
Real time clock w/ alarm functions, event scheduling and sleep timer
6 Configurable global preset commands and page preset
Aluminum front panel w/ LCD & LED indicators
USB, RS-232 and infrared ports for discrete control and monitoring
Program via PC, optional keypads, or LCD front panel
Looped 1.5 second .wav file can be uploaded for use with page preset feature
Zone linking capability
4 Buffered infrared emitter ports (2 w/ IR routing)
34-Pin ribbon cable expansion bus input / output for passing of data, IR, Amp-On and audio to up to 32 zones
12V power output (x2) and 12V Amp-On zone outputs (x5)
Paging & status terminals
Firmware upgradeable
Optional rack mount kit available- IRK-130-4
Keypads / Controllers
Zones can be controlled via PC software, optional keypads or IR remote
IR remote not included
Discrete IR commands for all 32 zones for control via universal remote (no keypad required)
KEY-2.7 Features
Tactile buttons
Customizable source button name/layout
Standby, Mute, Volume Up/Down, 6 source selects
Volume level & power on status indicators
Plasma friendly IR receiver
Single gang mounting w/ RJ-45 connection
KEY-5.7 Features
Same as KEY-2.7 w/ the following additional features:
Backlit buttons
10 button numeric keypad
Transport & skip buttons
Source select buttons are long press/dual function
IR learning capability
Retail on the setup was $1900 - Asking $600 shipped.
