Outlaw Audio 7500 5 x 200 RMS
pecifications
Power output: 200 watts RMS x 5 (all channels driven simultaneously into 8 ohms from 20 Hz to 20 kHz with less than 0.03% total harmonic distortion). 300 watts RMS x 5 @ 4 ohms
Signal to Noise: >120dB below rated FTCfull bandwidth power
Power Bandwidth: 5 Hz - over 100 kHz (+0/-3 dB)
Crosstalk: Greater than -100 dB from 20 Hz to 20 KHz
Intermodulation Distortion: Less than .03% from 250mV to full rated FTC power
Voltage gain: XLR 34dB, RCA 28dB.
Slew rate: 50 Volts/microsecond
Remote Trigger voltage: 3 - 32 volts DC
Power requirements: 115 V 50-60 Hz
Power consumption: 1,800 watts (maximum)
Dimensions (W x H x D): 17.2 x 7.75 with feet x 18 (inches)
Weight: 80 (lbs)
Forgot the pics. Using the ones from Outlaw itself. Will upload pictures this evening to show the condition...
