FS: Harman Kardon PA2000 Amp
Status
Not open for further replies.
Duffinator
Duffinator
I have a barely used HK PA2000 amp with all original packaging. This is a 2x100 or 4x45 wpc amp. The specs are below and it's a typical HK with conservative WPC rating. I used this amp to power my patio speakers for one year and then bought a 7.1 channel AVR and used it's extra two channels to power my patio speakers. It's been boxed up for almost five years. I powered it up and it works fine. $200 delivered to your home via UPS ground. It's in perfect condition with no visible marks. Paypal for immediate shipping or if you use a personal check you'll have to wait until it clears before I ship it. Please send me a PM if you are interested.
Here's a link to the Manual:
http://manuals.harman.com/hk/Owner%2...120V) OM.pdf
The PA2000 gives you high performance sound with the flexibility for home theater or multiroom operation! It can be used in four channel mode so that you can have two separate multiroom stereo systems or the four channels can be bridged into two supercharged channels for maximum power! And if your 5.1 channel surround system has 7.1 channel outputs, you can even use the PA2000 to upgrade to 7 channel operation!
Features
Power Output, Normal Mode: 4 x 45 Watts @ 8 ohms, 20Hz - 20kHz, <0.07% THD, all channels driven
Power Output, Bridged Mode: 2 x 100 Watts @ 8 ohms, 20Hz - 20kHz, <0.07% THD, all channels driven
High Instantaneous Current Capability (HCC): 45 Amps
Frequency Response: <1Hz - 170kHz (-3dB at 1 watt)
Signal-to-Noise Ratio: 110dB at Rated power 45 watts
THD/IMD: Less than 0.07% at rated output
Power Bandwidth: <1Hz - 100kHz
Input Impedance: 47k Ohms
Input Sensitivity: 1 Volt for rated output
Dimensions
(H x W x D): 6-1/8-Inches x 17-3/8-inches x 15-3/4-Inches (155mm x 442mm x 400mm)
Weight: 25.3 lb (11.4kg)
Warranty: 2 years parts and labor
Line-level outputs for daisy-chaining amplifiers
Automatic turn-on connections
Variable output level controls
Gold-plated, 5-way binding-post speaker terminals
Insider Tips:
The PA 2000 is a wide-bandwidth design, which means it will more effortlessly replay upper treble and lower bass. It is also a high current design, which gives it greater control over bass than competing models. It also features discrete output devices instead of cheaper integrated circuits--which is a sign of quality. These features tell more about the sonic output capability than does mere wattage--i.e.., a wide-bandwidth, high-current, discrete output design will produce more clarity, better bass, greater dynamics and superior speaker control than competing designs that have even double the rated wattage.
Tech Specs
Product Type - Amplifier
Dimensions (WxDxH) / Weight - Amplifier : 17.4 in x 15.7 in x 6.1 in / 25.1 lbs
Width - 17.4 in
Depth - 15.7 in
Height - 6.1 in
Weight - 25.1 lbs
Sound Output Mode - Stereo
Response Bandwidth - 1 - 170000 Hz
Signal-To-Noise Ratio - 110 dB
Input Impedance - 47 kOhm
Input Sensitivity - 1 V
Amplifier Output Details - 45 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 4 channel(s) ( main ) 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 2 channel(s) ( main )
Additional Features - Auto power on/off, dual volume control
Connector Type - 1 x audio line-in ( RCA phono x 2 ) - rear 1 x audio line-out ( RCA phono x 2 ) - rear 1 x trigger - rear 4 x speakers output ( banana/spade x 2 ) - rear
Power Device - Power supply - internal
Voltage Required - AC 120 V ( 50/60 Hz )
Power Consumption Operational - 260 Watt
Duffinator
Duffinator
The PA 2000 is still available but the HK AVR 7200 is sold.
Duffinator
Duffinator
One last bump before it gets listed on eBay.
Duffinator
Duffinator
Price lowered to $180. This amp is in like new condition.
Papichulochgo
Is It Still For Sale
Where can I E-mail you at?
Papichulochgo
Location/Price
Earl,
Where are you located? How much are you asking for it? Where can I E-mail you for more information?
Duffinator
Duffinator
It's still available. I sent you a PM with my email address.
Seth=L
Seth=L
It seems you aren't the only one having trouble selling an excellent amplifier.:eek:
Duffinator
Duffinator
I sold my HK AVR 7200 in a couple of days. I have this listed on a few sites but only a couple of nibbles.
As you can see from the photos it's in new condition and probably only has 40 hours of use before I stored it in my closet. Hopefully it will find a new home soon.
Status
