What can I say about Bryston that has not already been said. A quick google search will tell you all that you need to know.
Im the 2nd owner of this unit that was originally purchased I believe in 2003-2004 and resided in a smoke free dedicated room and still under the 25 year warranty.
The Bryston 4B SST amplifier comes with an output of 300 Wpc into 8 ohms, and 500 Wpc into 4 ohms, which delivers a high volume sound. Enjoy lowest to highest frequencies with this Bryston 2-channel amplifier that features a frequency response that ranges from 20 Hz - 20 kHz. With a signal to noise ratio of 113db, this Bryston power amplifier separates voice and effects from background noise to deliver a pure sound. This Bryston 2-channel amplifier sports a heat sink design which dissipates the heat, which results in maximum cooling in hot conditions. This Bryston power amplifier consists of a selectable gain between 29dB for balanced inputs. Boasting a push on/off power switch, the Bryston 4B SST facilitates an easy operation Product Identifiers Brand Bryston Model 4B SST MPN 4B SST Key Features Frequency Response 20 Hz - 20 kHz Number Of Channels 2 Tech Details Audio SNR 113 dB THD (Total Harmonic Distortion) 0.05 % Dimensions Depth 5.25 inch Height 17.25 inch Width 19 inch Weight 50 lbs Unit is still under full Mfg. warranty and has very low hours used. well maintained in clean smoke-free environment comes complete with original box and packaging power cord and manual. all complete and ready to go !
