FS: AV123 ELT525C Center Speaker ~ $80
E
exospire
I'm in the process of upgrading from my ELT525 5.0 set. Already sold my monitors on craigslist, but he didn't need a center. I figure there has to be someone somewhere that needs the ELT525C, so I figure I would start here.
Looks great, there is one scratch on the top that you wouldn't really notice unless you were close. Other than that, prestine condition.
System Description: 2 Way
Woofer: 2x 5.25" treated paper cone
Tweeter: 1" fabric dome with oversized surround
Enclosure Type: Vented, Rear Firing
Frequency Response (+/-3dB): 74Hz- 20KHz
Nominal Impedance: 8 Ohms
Sensitivity: 86dB @ 1w/1m
Crossover: 2400Hz, 2nd Order Acoustic
Raw Weight: 16lbs each / 7kg each
Dimensions: 17.7" W x 6.2" H x 9.9" D / 449.5mm W x 156mm H x 250mm D
Mounting: 1/4"-20 threaded insert built into the back
Video Shielded: Yes
Price is for local pickup. I'm in Fresno, CA
