FS: Audiosource EQ 100
L
Lagger
$40 obo. Prefer local pick-up. If not, buyer pays shipping. Dont have the weight, but pretty light. I'd say around 5.0 lbs. No manaul.
The specs:
The AudioSource EQ 100 is a versatile, affordable graphic equalizer. Illuminated LEDs in the twenty sliders let you check your settings even from across the room. The bright spectrum analyzer displays allow you to monitor your systems output. Left and right sliders can be set independently, as can level controls for each channel.With a 90 dB signal to noise ratio and 0.03% THD, the EQ 100 quietly balances your system.
Frequency Response 10 Hz - 50000 Hz
THD 0.03 %
Signal To Noise Ratio 90 dB
Height 2.5 in.
Depth 8 in.
Width 16.5 in.
This EQ is in perfect shape. Nice graphic display. Loops well with the Pioneer thats For Sale that EQ's everything that plays through it. My yamaha doesn't have the same flexibility so it's up for sale.
The pics:
malvado78
malvado78
You know you could have put all these items into one post. This isn't like ebay where you have to put everything up seperate.
L
Lagger
Bump.....why use tone controls when you could use an EQ? ;)
Methost
How do you loop an eq when you are using an AV receiver? What is the connection process?
L
Lagger
Use the Tape 2 monitor function with two sets of RCA's. One set is 'In' and one set is 'Out'. RCA's included.
Methost
And that loops EVERYTHING through the EQ? Even the digital inputs? ... or what about SACD or DVD-A. I am confused as to how this could work.
