Older Components taken out of a 3 year old installation. I have (8) CPC-CAMI and CNPWS-75. (2) Extron 8 input RGB switchers (one with RGB, Component, S-Vid and Composite outputs), (Multiple) Extron RGB 192, (2) Crestron CT-3500 touch panels, Crestron Frame (predecessor to the Pro2, I cant remember the model number) Oxmor volume control (back end only), (3) Tandberg Codec (either 2500 or 3000, not sure) (2) channel EQ, Composite and S-Vid to RGB converter, Boston Acoustic Bookshelf speakers (older model, hardly ever used still in original box), Pro quality dual tape deck, Full AMX control systems (touch panel, frame, components ect.). I have lots of older used components that have been removed from buildings that are going to be remodeled. If you need a particular part please ask and I will see what we have on the surplus shelf.
Please ask any questions you might have and I will be more than happy to help.
Thanks,
Pat
